When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-11-12 02:01:40
Point:500 Replies:19 POST_ID:828419USER_ID:11059
Hypertext Markup Language (HTML);;JavaScript
Just want to how to dectect enter key after users input product No: in inputbox.
When users press enter key, the URL will redirect to other link accroding to inputbox
product NO and display page in second frame in the same window of inputbox.
After redirection is completed, the inputbox will be clear for users to be ready
for next edit product No:. So the question, how to write a code for onkeydown to
dectect enter key and do clear inputbox value for user next edit ?
THe following javascript code is finished inputbox, frame set for URL redirect, onclick clear vlaue operation but except final one for detecting enter key to clear input box vlaue for next product
NO edit
Ducan
NO edit
Ducan
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/loose.dtd"><html><head><meta http-equiv="Content-Type" content="text/html; charset=utf-8"><title>Testing Input Box</title><TITLE>Document Title</TITLE><script>function formSubmit(frm){ document.getElementById("frame1").src="http://www.mywebsite.com/"+frm.text1.value+".htm";onkeydown="if (event.keyCode==13) {frm.text1.value=''}" return false;}</script></HEAD><body><style>.highlighted { background-color:white; }</style><form onsubmit="return formSubmit(this)"><input type="text" name="text1" value="0000" onclick="this.value=''; this.className='highlighted'" onblur="if(this.value=='')this.value=this.defaultValue; this.className=''" /><input type="submit" name="submit" ></form><iframe height="700" width="1400" scrolling="no" border="0px" id="frame1" src="http://www.mywebsite.com/index.htm"></body> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:
Author: duncanb7 replied at 2024-11-12 17:14:20
Yes, your are right, I also
put el.value='' that is also working
if (key==13){
fn();
el.value='";
return false;
if (key==13){
fn();
el.value='";
return false;
Expert: SouthMod replied at 2024-11-12 15:20:32
Per author request (http://www.experts-exchange.com/Q_26610487.html) I've reopened this thread. The comment accepted originally was: #a34119549
SouthMod
EE Moderator
SouthMod
EE Moderator
Author: duncanb7 replied at 2024-11-12 08:58:28
Dear TiberiuGal,
Could you comment this new thread at
http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/Q_26611155.html ?
please advise
please advise
Author: duncanb7 replied at 2024-11-12 04:29:28
if (key==13){
fn();
el.value='";
return false;
if (key==13){
fn();
el.value='";
return false;
Expert: TiberiuGal replied at 2024-11-12 04:16:35
I missed that part :
function formSubmit() { var my_val = document.getElementById('text1').value; // check if value is empty if ( my_val.length > 0) { document.getElementById("frame1").src="http://www.mywebsite.com/"+ my_val +".htm"; } document.getElementById('text1').value = '';} 1:2:3:4:5:6:7:8:9:10:
Author: duncanb7 replied at 2024-11-12 04:16:33
I mean after enter key is pressed,
formSubmit() function activate first or do first for redirect, and then check enter key operation is next
to clear input box so user doesn't need to click the input box again for next edit
Author: duncanb7 replied at 2024-11-12 04:14:51
Actually you understand my question ?
Do i need to write it again
Author: duncanb7 replied at 2024-11-12 04:12:12
Okay it is back to previous thread status, for example,
Edit 66666 and Press enter ,and redirect it is sucessful t0 .../66666.htm but
66666 number is still in input box not clear so user needs to click again for next edit.
So, the checkenter is not done yet , Please advise
Expert: TiberiuGal replied at 2024-11-12 03:59:56
I see, the function formSubmit references the form, we need to change that reference by adding an id attribute to the text box
function formSubmit() { var my_val = document.getElementById('text1').value; // check if value is empty if ( my_val.length > 0) { document.getElementById("frame1").src="http://www.mywebsite.com/"+ my_val +".htm"; }}<input type="text" name="text1" id="text1" ... 1:2:3:4:5:6:7:8:9:10:11:
Author: duncanb7 replied at 2024-11-12 03:57:51
onkeydown="return checkEnter(event, this, formSubmit);" />
to be repacled by onkeydown="return checkEnter(event, this, formSubmit() );" />
Is it correct ?
Is it correct ?
Author: duncanb7 replied at 2024-11-12 03:56:20
Dear TiberiuGal,
When delete <form onsubmit="return formSubmit(this)"> and then
redirect to www.mywbeiste.com/66666.htm is failed. it is getting worse
than the previous thread
Please advise.
Please advise.
Author: duncanb7 replied at 2024-11-12 03:44:25
http://www.experts-exchange.com/Community_Support/General/Q_26610487.html
Sorry again, I already submit re-credit form to EE adm
Author: duncanb7 replied at 2024-11-12 03:40:45
Sorry the point is going to expert, TiberiuGal, and I will re-credit in since I score it too fast
Expert: Bardobrave replied at 2024-11-12 03:37:18
onKeyDown fires everytime a user press a key within the focused object.
If I understand what you want, you only need to make a function that fires on product number keyDown where you recover the value on product number input, change the action of your form according to this readed value when keyCode pressed is 13 and finally submits the form.
Expert: TiberiuGal replied at 2024-11-12 03:34:51
<script type="text/javascript">// e - event, el - element, fn- callback functionfunction checkEnter(e, el, fn) { var key=e.keyCode || e.which; if (key==13){ fn(); return false; } return true;}function formSubmit() { var my_val = frm.text1.value; // check if value is empty if ( my_val.length > 0) { document.getElementById("frame1").src="http://www.mywebsite.com/"+ my_val +".htm"; }}</script><!-- there's no need of a form if you handle it via an iframe --><input type="text" ...onkeydown="return checkEnter(event, this, formSubmit);" /><input type="button" value="submit" onclick="formSubmit();" /> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:
Expert: TiberiuGal replied at 2024-11-12 03:29:55
Fix:
Expert: TiberiuGal replied at 2024-11-12 03:28:12
you can use onkeydown without a problem. But the formSubmit function doesn't make sense to me.
here's how I'd write it
<script type="text/javascript">// e - event, el - element, fn- callback functionfunction checkEnter(e, el) { var key=e.keyCode || e.which; if (key==13){ fn(); return false; } return true;}function formSubmit() { document.getElementById("frame1").src="http://www.mywebsite.com/"+ frm.text1.value +".htm";}</script><!-- there's no need of a form if you handle it via an iframe --><input type="text" ...onkeydown="return checkEnter(event, this, formSubmit);" /><input type="button" value="submit" onclick="formSubmit();" /> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:
Author: duncanb7 replied at 2024-11-12 03:06:58
I think I could not use onkeydown because there is onclick and onsubmit operation, and I need those two
operation is finished and detecting last key of enter key, so I should put detecting ocde in the function
formSubmit(frm), Right ? but the following code is not working because I don't know what is the event
if (event.keyCode==13) {frm.text1.value=''};
return false;
return false;
Expert: Bardobrave replied at 2024-11-12 02:48:58
Take a look at this:
http://www.w3schools.com/jsref/event_onkeydown.asp
The keyCode for Intro if I remember well is 13
