When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-11-11 12:23:08
Point:250 Replies:13 POST_ID:828417USER_ID:11059
Hypertext Markup Language (HTML);;JavaScript
First time, When I create input box, and type production No, for example, 666666 and then
redirect other new webpage according to input box's input into second frame in the same IE window. My question is When I type second times, for example, 1213458, I need click the input box first and then backspace the first edit in the input box like 6666666 until empty box and then type seond time eidt like 1213458. IS there any way in html or javascript can let the input box edit without need to
backspace to erase previous edit. Like when mouse clicking input box area and then automatically erase the input box's previous edit . That will help to be user friendly feature
Second question, how to highligh or give background color for the input box 's text value in the input box when mouse is clicking
<HTML>
<HEAD>
<META NAME="GENERATOR" Content="Microsoft Developer Studio">
<META HTTP-EQUIV="Content-Type" content="text/html; charset=iso-8859-1">
<TITLE>Document Title</TITLE>
<script>
function formSubmit(frm)
document.getElementById("frame1").src="http://www.mywebsite.com/"+frm.text1.value+".htm";
return false;
</script>
</HEAD>
<body>
<form onsubmit="return formSubmit(this)">
<input type="text" name="text1">
<input type="submit" name="submit">
</form>
<iframe width="600" border="0px" id="frame1">
</body>
</HTML>
<HTML>
<HEAD>
<script>
return false;
</script>
</HEAD>
<body>
</form>
</body>
</HTML>
Author: duncanb7 replied at 2024-11-13 04:21:23
Do you tink I use onkeydown in Javascript that will help
to erase the previous value once the previous webpage search is done so
it is not neccessary the user to click input box again since it is done by onkeydonw
detecting the enter key of "13"
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title>Testing Input Box</title>
<script>
document.getElementById("frame1").src="http://www.e-hftrade.com/"+frm.text1.value+".htm";
onkeydown="if (event.keyCode==13) {frm.text1.value=''}"
return false;
</script>
</HEAD>
<body>
<style>
.highlighted { background-color:white; }
</style>
<input type="text" name="text1" value="0000" onclick="this.value=''; this.className='highlighted'"
onblur="if(this.value=='')this.value=this.defaultValue; this.className=''" />
<input type="submit" name="submit" >
</form>
<iframe height="700" width="1400" scrolling="no" border="0px" id="frame1" src="http://www.website.com/index.htm">
</body>
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
Expert: _alias99 replied at 2024-11-12 19:24:37
duncanb7,
Please award points to any responses that answer the original question you have posted here (the question at the top of this thread).
This should be your only consideration in awarding points.
For any new/additional question you should use a seperate thread.
Experts,
Please post your recommendations for closing this question after my comment here.
Thank you,
_alias99
Comunity SUpport Moderator
Experts,
Thank you,
_alias99
Author: duncanb7 replied at 2024-11-12 03:12:46
Please help and advise
Author: duncanb7 replied at 2024-11-12 03:11:38
Anyway, ii ncrease the point , please reply it for the new thread and score it for you 500 including this answer in this thread
Expert: TiberiuGal replied at 2024-11-12 02:17:24
This thread already got answered, so there's no reason moving it.
Just create a new thread for the remaining questions.
Author: duncanb7 replied at 2024-11-12 02:12:30
Dear TiberiuGal and sam2912,
I will delete this thread since I will make new thread and increase point of the thread and
write it cleary for the remining question. And sorry, this thread and code has a lot of typing
error and not clear enough. Please switch to the new thread and Advise at
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/HTML/Q_26610335.html
Expert: sam2912 replied at 2024-11-11 18:47:41
TS, you are trying to link multiple questions in this thread. Plus, it is worth lower than-average points. It is highly recommended you split this up.
Author: duncanb7 replied at 2024-11-11 15:55:49
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
Author: duncanb7 replied at 2024-11-11 14:15:06
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
Author: duncanb7 replied at 2024-11-11 14:13:29
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
Author: duncanb7 replied at 2024-11-11 14:10:49
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
Author: duncanb7 replied at 2024-11-11 14:06:41
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
<html>
<head>
<script>
return false;
</script>
</HEAD>
<body>
<style>
</style>
</form>
</body>
Expert: TiberiuGal replied at 2024-11-11 13:30:37
