and insert other new text code rigth below the search location in html file. Please
see the following code area for Function searchtext2(), Now I would like to modify
searchtext2() for a new function that is replace a text right after first character position in search a text location in html by VBA coding, For example, search ("shLink")[0] and will be reaplced by ("shLink"[g_iSh]
Example.HTM
"<frame src=""+document.all.item("shLink")[0].href+"" name="frSheet" noresize>"+
Plese advise
Sub searchtext2()Dim workbookname As StringDim searchtext As StringDim ReplaceText As StringDim rFile As Stringworkbookname = ActiveWorkbook.Path & "example.htm"searchtext = "<script language=""JavaScript"">"ReplaceText = searchtext & vbCrLf & " var g_iSh = 0;" & vbCrLf & _ "if (window.location.search)" & vbCrLf & _ "g_iSh = window.location.search.split(/=/)[1];" & vbCrLf & _ "window.setInterval(""refreshPage()"", 10000); //refresh every 10 sec" & vbCrLfrFile = ReadFile(workbookname)rFile = Replace$(rFile, searchtext, ReplaceText, 1, , vbTextCompare)WriteFile workbookname, rFileEnd SubSub WriteFile(sFilePathAndName, sFileContents)Dim oFSDim oFSFile Const ForWriting = 2 Set oFS = CreateObject("Scripting.FileSystemObject") Set oFSFile = oFS.OpenTextFile(sFilePathAndName, ForWriting, True) oFSFile.write (sFileContents) oFSFile.Close Set oFSFile = Nothing Set oFS = NothingEnd SubFunction ReadFile(sFilePathAndName) Dim sFileContents Dim oFS Dim oTextStream Set oFS = CreateObject("Scripting.FileSystemObject") If oFS.FileExists(sFilePathAndName) = True Then Set oTextStream = oFS.OpenTextFile(sFilePathAndName, 1) sFileContents = oTextStream.ReadAll oTextStream.Close Set oTextStream = Nothing End If Set oFS = Nothing ReadFile = sFileContentsEnd Function 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:
Okay now understand. it should be no problem because
it used 'ReplaceText = searchtext & vbCrLf & " var g_iSh = 0;" & vbCrLf to
keep"<script text>
keep"<script text>
keep"<script text>
keep"<script text>
