When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-10-20 14:14:37
Point:500 Replies:2 POST_ID:828385USER_ID:11059
VB Script;;Visual Basic Programming
I'am doing automation for download 100 files from one website, before
clicking save button after clicking download bar in the website, I would like
to see the filename is matched to my expect or not before I click the save button.
SO I try to read the filename in the download popup daiglog window's "Edit"(WM_Edit) box.
For example, the following simplify code, And I use SpY++ to check the download
diaglog windows 's HWND and found "edit" box 's HWND shown
on SPY++ too, but I could not extract the title name(it means the filename in edit box)
by getwindowtext with getwindowtextlength. I can get the title of "button" class name
in the download popup dialog window but always failed to get the title of the "edit" (WM_EDIT) classname
whose title name should be same as the default download filename sent or provided by the website
Sub test()
Dim hdlg as string
hdlg = findwinodw(vbnullstring, "Download files Window" ' That appears after clicking the
download bar in the webiste
hdlg2 =findwindowEx(hdlg, 0, "Edit", vbnullstring) ' There is edit box for users to change the filename
from the default filename but it is failed and hdlg2 alwayws is 0
debug.print Getwindowtextlength(hdgl2), but it also failed, it showed nothing
End Sub
PLease advise, what is wrong with the code, WHen I test the "button" class name that is
okay I can get the title of "SAVE" with debug.print but not for "Edit" class name
SPy++ show the title of the "Edit box" is same as filename in Edit box in the daiglog windows,
it should be really easy to extract but it is fail and I hung up here.
Sub test()
Dim hdlg as string
End Sub
Author: duncanb7 replied at 2024-10-21 06:56:17
it works fine and thanks for all of you to reply
Expert: xxlc replied at 2024-10-20 17:23:28
