When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-21 05:52:46
Point:250 Replies:7 POST_ID:828360USER_ID:11059
Visual Basic Programming;Miscellaneous Programming;JavaScript
When I navigate the bank login website page by VBA with .navigate, and I found there is
no any element ID or type for username and password in the source code of html. It is
javascript function to let user to access the login page. So I need to use sendkey("myloginname")
instead of .document.all("username")="myloginname" to enter my login name in the webpage . The problem is when I run the sendkey("myloginname") in VBA, the "myloginname" is pasted on my VBA code not the location of the login box of the login page I navigate. How Can I control my cursor and move it to the bank page and exact login box?
I tried the sendkey() before, sometimes, it works but sometime it doesn't work as I said above.
it seems it is related to cursor position issue ?
Please veiw the following code espeically with Bold type for the sendkey which will send the
myloginname inside of my banklogin() code.
My code is here :
Sub Banklogin()
Dim myIE As SHDocVw.InternetExplorer
Set myIE = Nothing
Set myIE = CreateObject("InternetExplorer.Application")
.navigate "www.mybank.com"
call waiting
sendkey ("myloginname")
myloginname.document.links(6).click 'enter the next page of login
End Sub
Function WAITING(ByRef myIE As SHDocVw.InternetExplorer)
With myIE
Do Until Not .Busy And .readyState = READYSTATE_COMPLETE
Loop
End With
End Function
My code is here :
Sub Banklogin()
Set myIE = Nothing
call waiting
End Sub
With myIE
Loop
End With
End Function
Author: duncanb7 replied at 2024-07-21 08:13:07
Thanks for all of you to reply this
email
Author: duncanb7 replied at 2024-07-21 08:12:34
email
Expert: JohnBPrice replied at 2024-07-21 07:34:36
Expert: JohnBPrice replied at 2024-07-21 07:29:25
250 points GOOD
email
Expert: amdefacto replied at 2024-07-21 07:06:49
email
Author: duncanb7 replied at 2024-07-21 06:14:38
email
Author: duncanb7 replied at 2024-07-21 06:12:46
email
