When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-06-25 04:06:57
Point:250 Replies:3 POST_ID:828350USER_ID:11059
Visual Basic Programming;;
I have tried to open a excel file and copy one of its sheets into other new sheet in the same file,
for example, the code as follows
'"template" sheet is in out.xls and is copied into new sheet call "result"
Workbooks.Open Filename:= _
"d:out.xls"
Workbooks("out").Sheets.Add.Name = "Result"
Sheets("template").Select
Sheets("template").Copy
Sheets("Result").Select
Sheets("Result").Paste
The code is fail and have run-time error, the paste operation is not done on "Result" sheet but it paste in on other new sheet "BOOK2" created by Excel 2003 instead, Please advise what is wrong with these.
The other question what is meaning of .copy after:= or .copy before ... Where I could know the defintion of
copy synax in VBA ?
BR
"d:out.xls"
copy synax in VBA ?
BR
Author: duncanb7 replied at 2024-06-25 04:32:37
copy after/ before referres to the order the new sheet will be created.
copy after creates the new sheet after the already existing one, while
copy before creates the new sheet before the already existing one.
you can experiment a lot with recording a macro, then check the source of it.
Regards,
István
Expert: nagyistvan replied at 2024-06-25 04:21:18
Regards,
István
Expert: nagyistvan replied at 2024-06-25 04:18:51
