files , for example, the jar file at the link at http://mirrors.ibiblio.org/pub/mirrors/maven2/milyn/j2ee/1.4/j2ee-1.4.jar by command
jar xf j2ee-1.4jar that will create one directory called javax. And then I do the reverse by the command
jar cvf junk.jar javax, junk.jar is created but its size is 789k which is totaly different from orginal one of 1668k
from j2ee-1.4.jar. Because I could NOT attach my jar file into exchange-expert link, so I made this j2ee-1.4.jar as my similar problem. COuld you tell me why whether I use wrong option on jar command
Suppose both file size of junk.jar and j2ee-1.4.jar is same
Question-2: I don't understand actully meaning of manifest . What is its pupose for Jar proccess, Just
from websearch explain this with " Manifest is an XML based, database driven Content Management System (CMS) for satisfying corporate communications needs, including Internet and Intranet"
Question-3, please possilbe, please download the file to test it at your side
Please advise it kindly
I mean extract example.jar file and combine the jar file example directory to create example-test.jar.
Both example.jar and example-test.jar should be exactly same in format and file size, Right ?
Please advise it , if possible,please try the j2ee-1,4.jar to do extract jar file and combin jar file directory
