The error is at last line in attahced code about not finding the symbol of
getContentPane().add(panel,BorderLayout.CENTER); I already include
everything of java at the begining line of the code but still get the following
error.
Please help on this, and I suspect I use wrongly code about "public static void main(String[] args) { " at the last serveral lines in the code That may be bad code when I am using Applet to display the chart output result in IE with HTML code
Why Javac could not find out the symbol of getCOntentPane() ? That is
supposed not too difficult ..Right ? Or Is the error related to JPanel();
And other question , html code I write at last line of this email is problem
regardless of my code of Java code of "simplearea.java"
Please kindly advise and help on it
javac Error:
D:wkwSummaryINTERN~1CHART-~1javademo>javac -classpath "ChartDirector_s.jar;." simplearea.java
simplearea.java:95: cannot find symbol
symbol : method getContentPane()
1 error
I want use HTML code with Applet to display chart output result in IE as follows:
<HTML>
<HEAD>
<TITLE>A Simplearea (1.6)</TITLE>
</HEAD>
<BODY>
<h1>A Simplearea (1.6)</h1>
<hr>
<applet code="simplearea.class" archive="ChartDirector_s.jar" width=170 height=150>
alt="Your browser understands the <APPLET> tag but isn't running the applet, for some reason."
Your browser is completely ignoring the <APPLET> tag!
</applet>
</BODY>
</HTML>
/* Demo example of "simplearea.java" */import java.awt.*;import java.awt.event.*;import javax.swing.*;import ChartDirector.*;import java.applet.*;import java.io.*;import java.util.*;import javax.swing.event.*;import javax.swing.border.*;import javax.swing.JButton;import javax.swing.JComponent;import javax.swing.JFrame;import javax.swing.JLabel;import javax.swing.JPanel;import javax.swing.JTextArea;import javax.swing.SwingUtilities;import java.awt.BorderLayout;import java.awt.Font;import java.awt.GridLayout;import java.awt.event.ActionEvent;import java.awt.event.ActionListener;import java.awt.event.KeyEvent;public class simplearea extends Applet implements DemoModule{ //Name of demo program public String toString() { return "Simple Area Chart"; } //Number of charts produced in this demo public int getNoOfCharts() { return 1; } //Main code for creating charts public void createChart(ChartViewer viewer, int index) { // The data for the area chart double[] data = {30, 28, 40, 55, 75, 68, 54, 60, 50, 62, 75, 65, 75, 89, 60, 55, 53, 35, 50, 66, 56, 48, 52, 65, 62}; // The labels for the area chart String[] labels = {"0", "1", "2", "3", "4", "5", "6", "7", "8", "9", "10", "11", "12", "13", "14", "15", "16", "17", "18", "19", "20", "21", "22", "23", "24"}; // Create a XYChart object of size 250 x 250 pixels XYChart c = new XYChart(250, 250); // Set the plotarea at (30, 20) and of size 200 x 200 pixels c.setPlotArea(30, 20, 200, 200); // Add an area chart layer using the given data c.addAreaLayer(data); // Set the labels on the x axis. c.xAxis().setLabels(labels); // Display 1 out of 3 labels on the x-axis. c.xAxis().setLabelStep(3); // Output the chart viewer.setImage(c.makeImage()); //include tool tip for the chart viewer.setImageMap(c.getHTMLImageMap("clickable", "", "title='Hour {xLabel}: Traffic {value} GBytes'")); } //Allow this module to run as standalone program for easy testing public static void main(String[] args) { //Instantiate an instance of this demo module DemoModule demo = new simplearea(); //Create and set up the main window JPanel panel = new JPanel(); /* frame.addWindowListener(new WindowAdapter() { public void windowClosing(WindowEvent e) {System.exit(0);} }); frame.getContentPane().setBackground(Color.white);*/ // Create the chart and put them in the content pane ChartViewer viewer = new ChartViewer(); demo.createChart(viewer, 0); panel.add(viewer); /* frame.getContentPane().add(viewer);*/ // Display the window /* frame.pack(); frame.setVisible(true);*/ getContentPane().add(panel,BorderLayout.CENTER); }} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:81:82:83:84:85:86:87:88:89:90:91:92:93:94:95:96:97:98:99:100:101:
Since ojects is first one to trigger me to finish my questiona dn answer , and
pramodkrjsr is also giving us a lot of great advise. It is hard to say who help
the most or first or later . I think Thermoduic will help this out
Thanks all of you to EE and sharing purpose together with fun and technical
BR
BR
BR
BR
BR
BR
BR
BR
BR
BR
BR
BR
BR
