at the link http://code.google.com/p/flot/ and http://jquery.com/ to do better and standalize
the world. Since I would like to convert data plot file format into XML format for excel and webpage
application, the data format of Jquery is different even it is also easy to convert.
Any Javascript expert, have some clear suggestion for standard plot and chart function library. Be reminded
it is free to download and user friendly
Question-2, if it is possible, I also want to learn how to wirte those plot , chart function in coding, any
tutorial website suggestion ?
Br
>COuld you give me more...
If I can yes of course. What do you want to know ? I saw you post an other similar question. I propose to you to continue on it.
I don't like SVG because its browser support.
Anyway thanks for the points
Excellent, COuld you give me more...
If you don't know what I need, I will
explain it one more time.
Hope you could help me through it that drive me a long long time
THanks
1 - http://code.google.com/intl/en-US/apis/visualization/documentation/gallery/motionchart.html (flash based solution)
2 - http://tutorials.jenkov.com/svg/index.html (check example)
