When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-06-07 09:48:46
Point:500 Replies:21 POST_ID:828322USER_ID:11059
JavaScript;;Java Server Pages (JSP)
Plot a chart in Javascript and JSPQuestion: Plot a chart in Javascript and JSPQuestion: There are may ways to plot a stock/billing chart on fly stream data in Javascript and JSP
Why people choose JSP in server to do the coding instead of leting client-side to do
coding in IE/Firefox. Which side (client-side or server-side programming ) is more
efficient and faster ?
Question-1 At yahoo, financial page, the chart of Dow Jones is making from Javascript
by cilient side or JSP script by the server side ? Why they're doing that ?
Question-2 How can I start to make a chart based on SVG standard from w3C.
What free library function of graph and chating is better and easier to be used ?
Question-3, If my csutomer is sending data at every second, how can I show him a
chart or graph on my home domain page to let him see our respomce. In other word,
after receiving his streaming data, I will do some fast internal calculation and send the
data to the chart on my website.
Question-4 Should I make my extract data into XML format or others in order to take
easy advantage to use the chart function from the library you suggest
Br Regards
Br Regards
Author: duncanb7 replied at 2024-06-07 12:53:21
See you Sir, have a good day
Author: duncanb7 replied at 2024-06-07 12:52:08
Expert: leakim971 replied at 2024-06-07 12:38:43
Expert: leakim971 replied at 2024-06-07 12:33:57
Author: duncanb7 replied at 2024-06-07 12:31:00
Author: duncanb7 replied at 2024-06-07 12:26:00
Author: duncanb7 replied at 2024-06-07 12:18:21
Expert: leakim971 replied at 2024-06-07 12:15:21
Expert: leakim971 replied at 2024-06-07 12:14:20
Expert: leakim971 replied at 2024-06-07 12:12:23
Author: duncanb7 replied at 2024-06-07 12:10:21
Author: duncanb7 replied at 2024-06-07 12:07:57
Expert: leakim971 replied at 2024-06-07 11:56:05
Expert: leakim971 replied at 2024-06-07 11:52:46
Author: duncanb7 replied at 2024-06-07 11:41:15
Expert: leakim971 replied at 2024-06-07 11:39:45
Author: duncanb7 replied at 2024-06-07 11:39:16
Expert: leakim971 replied at 2024-06-07 11:38:01
Expert: leakim971 replied at 2024-06-07 11:30:23
Author: duncanb7 replied at 2024-06-07 11:27:44
Expert: leakim971 replied at 2024-06-07 11:24:03
